Ecu wiring?? Bd5
H84WD
Bit confused on the ecu wiring so can someone point me in the correct direction, I’ve read the single turbo conversion threads but I am still unsure on what wires I have to swap on the loom to run a v3/4 ecu
Also wanting to wire in a bee r limiter, what wire do I use for cam signal (b5?) And also the rpm signal (b10?)
*unable to add ecu pin out on single turbo thread 🙃
cheers 😊
