Gidday subaru family, got a 2006 Subaru legacy gtb stock auto,  had a crack at replacing  the spark plugs today, got 3 of the 4 done before ran out of light (and a bit of patience), questions are, is it ok to drive on the 3 new plugs with one old? And do I have to remove the secondary air pump plastic piece to get to the plug and coil out, passenger side rear? Help is much appreciated, cheers
Yea you’ll be fine in the short term.
No idea on the air pump pipe. Both times I've done them I've had the air pump deleted already. It'll be a lot easier for using the right socket extensions with it out of the way for sure and it isn't a huge amount of work to unbolt and remove.
  • Similar Content
