[minor] Forum 'blurb' on FB
Joker
 Share
very rarely used so I doubt anyone will notice BUT can any smarties help?
I was helping with some housekeeping on another forums & noticed ours is similar
11 minutes ago, JoKer said:
[Reads from the General FAQ blurb]
I know where the "All We'll Drive" caption lives & is editable [Site name]
which [when I log out] is the 3rd section viewable
can anyone suggest or find (if you're bored enough) a way to make it look smart?
Can’t you just edit the forum section description which it picks up?
in the forums config where you make and delete new sections, find general FAQ and change the text description.
it may know the software we use and pick a section of a set type or number which happens to be knowledge base in our case. Eg knowledge base could be section number 1 and people added general later but the display order is changed to make general appear at the top.
can do & was my 1st thought tbh
but the use it gets (zero to none) it isn't worth it aye
but probably same answer for the FAQ section : I bet that gets zero use too
and what ever they've done they've just managed to fix the issue
was this
(was reading the "other projects section Blurb)
and now its this
Reply to this topic...
  Only 75 emoji are allowed.
 Share
