Oil leak
Matthat
Hey I have a forester with the ej2ot, its the ej205 I got told when I went to get a service on it that the rocker cover gasket is leaking, I can see under the car the leaking oil now, is it easy to fix and do myself or should I get a mechanic to sort it?
Thanks
Thanks
it's very easy, anyone can do it. Just make sure you don't over tighted the rocker over bolts when the new seals are in, or they will leak again in no time.
32 minutes ago, Matthat said:
Do I have to remove much out of the engine to get to the rocker cover gaskets?
Nah not a lot. Intake bits on drivers side and battery on passenger side so you're not fighting for room. You’ll need various length socket extensions and a flex joint as it can be a bit difficult to get the socket in the spark plug hole until you work out the right lengths for everything.
Have you bought the parts yet?
There is no need to remove the spark plugs??? You just need to remove 6 bolts on each side.. unhook the breather pipe... and pull it off.
Edited by Loren
True, was thinking about how I did it a few months back but replaced spark plugs at the same time
6 hours ago, Matthat said:
I'm pretty sure it's the passengers side with the battery.
That will be easier... just the battery and washer bottle to remove. TBH though these things often happen in pairs. Assuming both seals are the same age... they will be in a similar condition, and if one is leaking now, the other won't be far behind.
Jacking the motor up will make the job of replacing the seals easier... but is more work before and after the seal replacement... so 6 of one and half a dozen of the other really.
Now im not sure if it is the rocker cover gaskets as they both seem fine, I got the car a service about 7 weeks ago, the retards have overfilled the engine with oil by quite alot, the leak is on the driver's side as the oil is dripping off the oil pan and the cross member, any suggestions as to what it could be and how to sort?
So what is the oil level on the dipstick when warm currently? Easiest thing to do would be to get in there and clean it up as much as you can then go for a drive and try narrow down the leak again.
Could be the turbo oil drain too, they often start leaking down the back of the engine and can be misdiagnosed as something else as they can be a bit hard to inspect on some models.
