Push button non start. No repsonse to either of the two fobs.
B2203 Abnormal immobilizer power supply
B2204 Abnormal Steering Lock power supply
B2215 Abnormal ID Co
The above 3 error codes popped up by the auto electrical guys. Apparrantly this was rectified.
Following day car a non starter again.
Returned to auto electriican. Claims no fault codes and starts for them.
Anyone encounter these issues? If so what was the remedy? THanks
A
Nope but sounds like battery maybe s***.
if you have a charger put it on for a bit before you try and start it. Loads of battery issues with the lockdowns and sitting for months.
in the morning after sitting overnight you get problems. After a drive it’s got enough charge to not have issues for a while.
  • 7 months later...
  • 4 years later...
I have the same three codes. Did you find a solution?
A
What was the answer?
