Steering rack boot deflating too much?
eZ_Harry
Hi,
Just installed a new steering boot onto a V7 STi. Before re-installing the outer tie rod, I thought I'd check the boot was working properly, so I turned the wheel to full lock both ways. I've noticed that the boot seems to deflate (collapse in on itself) a bit more than I feel comfortable with. At full extension the top part of the boot collapses in with a big dent. Should there be some sort of breather port which prevents this from happening, or is it normal?
I feel like it would rip the boot if I left it like that for too long
Edited by eZ_Harry
15 minutes ago, lachlan said:
The whole point is they are sealed and baloon in and out like bellows ....
You need to think less
Sure... lengthwise they should move like a bellow. But do you also expect movement width wise? I've read that some steering racks provide air to the boots for exactly this reason
