Engine compatibility
paulngui
I have an auto BP Legacy GT and the engine died recently. I don't know all the details, as I live in the UK now and it's my dad who's been looking after it. He was taking it out for a run and said it made a "ratcheting" sound then lost power and wouldn't start again. It got towed to our local garage where they were unable to turn the engine by hand.
Assuming the heads and the rest of it are ok, can theoretically any EJ20 short block be used if needed? As a short term solution to get it moving under its own power a drop in long block would be another option, but just want to know if I need to be careful about variants, especially if it was mated to an auto vs manual. Or does this not matter? TIA!
Heads being ok could be a big assumption, I'd be looking at a long block.
Pretty much needs to be a ej20x quad avcs motor, Ideally get the same to ensure cam/compression is OK for the factory tune (might not even be an issue with these ecus), but you could just get the car reflashed with whatever motor you put in to know its safe.
