Hi all,
I have a 2012 Legacy DIT with a snapped CVT chain. The transmission in it is a TR690GBDCA. I've found 2014 WRX wreck with a TR690GB9CA. Any one know if these can be swapped?
The legacy transmission is somewhat rare so needle in a haystack trying to match that up. Transmissions look identical in side by side photos, but perhaps there's some internals different. Drive ratios are identical
Other option is rebuild, but want to close this loop first.
Thanks.
  • Sad 1
oh wow : thought they were bullet proof? mind you I've never played with a CVT
keen to learn too for 'future' me just in case I ever encounter this
not sure what the spec's or difference's could be, connectors / internals etc?
On 25/02/2025 at 12:25 AM, Gripless said:
https://legacypic.uk/transmission/search.php?type=tr690gbdca
says matching ratios with what you listed and also another model.
according to the site above the 9ca is listed against 2014 models all with FA not EJ engines?
are the bell housing and bolt pattern the same, you may need to get measurements to confirm.
Can always ring Subaru dealer and ask what supersedes your current gear box.
Legacy DIT is a FA20 Engine.
