heya
this is for my sisters GT wagon TT 94
am getting codes 61 62 63
this means fuel tank pressure sensor, fuel temp sensor, fuel tank pressure controll solenoid
could an old-blocked fuel filter cause this code?
any idea where to start would be great lol
oh yeah, what happens is, car will start, idle for abit then slowly die
and somtimes
car will start, drive fine for while but wont rev over 3000rpm and if you try it just dies
Hi, I am unsure of what it could mean but me and my mate are just wrecking a BG5 so if your local you can swap out bits n try figure out waht the problem is
Have you been rerouting any of the fuel pipes?
Hot fuel would/could cause those codes and symptoms.
Hot like in boiling, caused by rerouting to near to something hot(turbo), or not flowing back to the tank quick enough because you have modified the fuel rail, fuel pressure something like that.
