2002 legacy b4. Just had BOV, air filter, exhaust and boost gauge installed, now in 4th gear, loud knock and feels like 180km speed cut at around 5500k-6000k when accelerating with full boost at 15psi in 3rd or 4th gear, get the check engine light, and it goes into limp mode any ideas?
Check out Technical sticky at the top of Leggy forum.
Connect the two black connectors underneath the dash together, turn ignition off and read flashes from CHECK ENGINE LIGHT.
Use the fault code table in the stickied article to get the fault code.
