How To: Power Light Fault Codes
The "Power" light indicates transmission codes. The following self diagnosis will show any fault codes for the transmission.
To perform the self diagnostic test for EXISTING problems:
Warm up engine by driving at speeds greater than 12mph.
Stop vehicle and turn ignition switch OFF.
Turn ignition switch ON and make sure POWER indicator lamp comes on.
Turn ignition switch OFF.
Move selector lever to D and turn manual switch ON.
Turn ignition switch ON.
Move selector lever to "3" and turn manual switch OFF.
Move selector level to "2" and turn manual switch ON.
Move selector lever to "1" and turn manual switch OFF.
Partially depress accelerator pedal (to turn idle switch off).
Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
To perform the self diagnostic test for PREVIOUS problems:
Move selector lever to "1" and turn manual switch ON.
Move selector lever to "2" and turn manual switch OFF.
Move selector lever to "3" and turn manual switch ON.
Move selector lever to "D" and turn manual switch OFF.
Trouble codes:
11 - Duty solenoid A
12 - Duty solenoid B
13 - Shift solenoid 3
14 - Shift solenoid 2
15 - Shift solenoid 1
21 - ATF temp sensor
22 - Atmospheric sensor
23 - Engine revolution signal
24 - Duty solenoid C
25 - Engine torque control signal
31 - Throttle sensor
32 - Vehicle speed sensor 1
33 - Vehicle speed sensor 2
**Manual Switch = Hold Switch
Taken from http://www.svx-iw.com/svxiw/article/?category=faq#_Toc482082581
  • 3 months later...
  • 4 years later...
