GTB standard with exhaust cutout?
  • 1 year later...
Mine has that, well had it! the pulley wire on it broke, so i just cut it off completely and turned the butterfly valve so that it was always open. I noticed a small change in the sound, but nt many changes otherwise.
If your wanting a bit more power for no cost at all, do what ive done. Ive cut out 2 pieces of 4mm steel into the shape of half a gasket(the reason for half a gasket shape is that i can easily take them out when needed, rather than using washers on the bolts) it gives a gap of 8mm between the flanges and sounds awesome and the power gain is quite surprising! The advantage of it is that you can take it out whenever u want to and u never spent hundreds of dollars on it!
  • 2 months later...
  • 5 months later...
  • Joker unpinned this topic
