trailing arm & control arm bushes
I'll be upgrading the:
* rear trailing arm bushes
* rear control arms bushes
on my 89 RS leggy. Will the old ones come out easy.....or do they need a bit of persuasion with the trusty hammer!!........or do I need to get them pressed out and new ones pressed in? (wana avoid cost if i can)
Any advice to make the job as easy as possible appreciated. cheers
Too much Christmas cheer already for my Funky haha.
Wildturkey, you could get the entire trailing arm kits that include the adjustable bars too, then you dont have to worry bout getting bushes out, there are kits with urethane bushes and Redline do a solid pillow ball mounted one if you want something even firmer. Just a thought.
 Bemrose']
[quote name='wildturkey said:
thanks for the advice guys..............good stuff
you wont ever get a wof with these without modds
plus you need a cert
Hi........I wont get a wof with after market control arms?........or even rex control arms?..............they both need cert?
Rex ones you will, that's what I've got and they're fine.
Yeah i guess strictly speaking they should be certed. You could get some and fit them and try and get a WOF. Just don't take it to VTNZ or any of those WOF nazis.
Guest Bemrose
if you car has ABS then its pretty much a no go
i have the full set on my rex, and there is only ONE bracket for the ABS when there needs to be 2, and no a cable tie doesn't work so i am told lol
Guest Bemrose
aah sorry, just remember i have the set of 6 arms for the rear, and the auction if for 2,
i have a extra arms which hold those cables , and they are the ones i had big problems with !
this is before i could put the other arms on!
16767_1273237186304_1091135086_874326_30
Guest Bemrose
 Hailz']
[quote name='Bemrose said:
deff a good buy then
worked a dream on my rex, couldn't believe the difference
What were the differences you noticed just out of curiosity?
like its on tracks, so firm and stiff
well well worth the money, its hard to explain before and after
