Why you shouldn't put silicone brake fluid in your car
Took the v7 sti in for a service, that was all good. While it was there i got them to check out some noise (which was making a metallic sounding noise) in the calipers. Turns out someone has put silicone fluid in it and it has stuffed the seals on the piston or whatever (The brake fluid that bayswater put it didnt mix with the fluid that was in it and in turn floating to the top of the master cylinder). $600 later for the service and it now requires 4 new seal kits at $400 a pop PLUS LABOUR.
They fully stripped all the calipers down and cleaned, lubed and reassembled them. Spent two hours doing so
Don't you love it aye
Na I haven't done them, the car has stopped making the noise and work perfectly. Might be a bit of dealer BS. I mean if it was a serious safety issue they wouldn't have given me the car back to drive.
your title is wrong. you can put silicone brakefluid in your car, just not mixed with other fluids... your service agent must be a retard.
