Spring change "*&^%$#
stira
I have my HKS springs in my hot little excited hands. Have borrowed some spring compressors off a mechanic mate, then tried to undo the 17mm nut on top of my bilsteins and no go, just twists the shaft.
Any ideas? or do i just go to supercheap and buy a rattle gun for my compressor and be done with it.
Assuming it's the same as normal shocks, you need to hold the shaft still with an allen key, and then turn the nut. Apparently you can buy socket wrenches that have a hole in the middle for this purpose, I ended up using tube spanners. Although iirc from my reading, you can just rattle it off if you have enough power behind it
Read Hopai's epic suspension fail, lulz at the familiarity of 'F**KING TOPHAT IS STUCK THE F**K ON', giggle at the twisting shaft and twisting springs... then wince as you discover my struts are now sitting at a shop getting chopped into submission :P
Hope yours aren't THAT stuck. Rattle gun did nothing but nearly KO the lot of us here.
Just undid mine with the car still on the ground and everything else still tight. Was a piece of cake. Used a deep reach socket and put some vice grips around the outside of it - then used an allen key through the middle.
Guest Bemrose
haha i dont know why people use clamps, i have not used them once, just use your knees when rattle gunning it !!!!!!
and when putting new spring in just push like fuck down and braaap braaaap
done!
 funkytown said:
lololol one assumes you've got spring clamps on to stop you wearing it all on the chin!!!!
Yes, but that brings me to another querie, should the clamps just be on the springs or also on a solid part of the shock?
Shit air tools are fun,makes you feel like a real mechanic, hehehe
 stira']
**** air tools are fun,makes you feel like a real mechanic, hehehe
just on the spring coils man.. you need to compress the coils to take the pressure of the tophat.... if you holding the tophat and the spring at the other end then itl still fly off.
 funkytown']
+1 for safety 1st...hahaha
