Drove the 96 to get bits for the 95, chisel to remove steering lock, wire brushes to remove minor surface rust with power drill, and primer and paint to cover up the exposed metal surface... All being tomorrows project
 Jason47 said:
Sussed out parts and pricings for the 95 and found out apparently i cant legally weld the back doors shut, is this tru?
examined the mass amount of crap that needs to be washed off my 96, chch is good for covering your car in liquef**ktion, mite wash it nxt week if im allowd... Darn water restrictions
If you take out seats, weld up seatbelt holes and re register as a 2 door (2 seater) you should be able too I think...
Im sure this has been touched on before somewhere, maybe in the racing forum?
96 GT: drive it to where the 95 is
95 GT: removed bar that goes from one side of the car to the other and holds the steering wheel in place, using a wire brush attached to a drill i stripped off the surface corrosion then primed and painted it. Removed steering lock (finally) and attempted to remove windsreen - what a mess - any tips?
