 Subtle RS']
[quote name='G-unit said:
wonderd why when going up a large hill my seatbelt light flicked on quickly lol have no idea why as i had it on
thoughts?
try the wiring harness under the seat it sometimes gets caught up in the rails...
thanks for that, will check 2moro after work
Took engine and gearbox out of the hatch. Now it sits hilariously high and even my meager might can lift a front wheel off the ground.
Got the Impreza gearbox into it. Seems to fit pretty well and i think ill be able to use the stock gear shifter with no mods. And i can still use the stock speedo cable and axles :D
removed headers, up pipe, turbo, down pipe, and started removal of intake manifold
the custom up-pipe being part of the headers was a mission. even once removed from the headers wouldn't fit through the space to get in or out. i had to unbolt the engine and bench press it while my mrs's dad jimmied the bloody thing out. i don't imagine many people have bench pressed an engine before haha
Yeah, that's a bitch to do with an integrated up-pipe / headers combo. You need to undo the engine mounts and use a jack to raise the block, and have the car high enough off the ground that you can swing the headers around 180 degrees to make it fit. Had the same issue with mine.
Fixed broken headlight today, turned out to be a dead relay in the custom wiring harness. Plug, play!
On sunday: Keltik and I dismantled his hatch and installed the TEIN lowering springs in the TS-R ;D
 aim said:
Took it to subaru, borrowed their hoist. I have a busted universal :( f***.
2nd hand d/shaft time. theyre so cheap its not funny
