 94 Leone said:
Had to buy a new headlight thanks to random stones flicking up from behind trucks. Yay :/ 110+shipping from strongs. Hurrah for crystals
Cheap!
Continuing my pattern of working on Dairusire's RA more frequently than my own car;
- replaced differential support outrigger bushings (clanking noise gone)
- replaced brake fluid
- rebalanced all four wheels
- discovered that front wheels are bent :cool:
My car:
- drove it
- put petrol in it (you know you're pushing it when the estimated range goes blank)
Well technically it was yesterday but i took the bbod off and with diagnosis mode put UEC through each solenoid, put new iridium spark plugs in, changed the two rubber fuel hoses that join the EFI rails together under the manifold (leaking) PITA!. Put UEC through the manifold and changed the oil then disabled the rear exhaust port valve and permanantly opened it. Cleared all codes ...... What effin VOD?! This thing is seamless and has no hesitations EJ208D im pretty stoked : ). Today changing rear disks and pads and installing a manifold press gauge.
Discovered my front struts have a bit of play... so pulled one off the car and stripped it back to the insert, time to find someone to put new bushings in the lower housings...
Love having completely rebuildable bits though. Will also get them re-shimmed as they are, realistically, too stiff for a road car.
