4 minutes ago, calebwrx said:
I would've thought camber should be even and that less caster on the left will compensate for the camber of the road. Was it a full alignment or a typical 'alignment' aka toe check?
For $89 I'd expect a more than just the basic toe check. Will probably go elsewhere in future.
It seems to be the new standard in pricing. I have rung everywhere in Wellington and they all said $90.
On Monday, the store manager at hyper said they got a brand new $120k laser alignment machine at hyper penrose. @1randomkiwi
Don't know what effect that will have on alignments xD
Once I do my struts this weekend, i'll probably take it to autoline aye. They are happy to align to your specifications as well.
You want more caster on the left to counter the camber in the road. You have the opposite and it's not adjustable on your car. So running more camber on the left is the way to go. But it looks like you got a toe and go with no camber changes.
Tip, next time you need a wheel alignment set the camber well out of spec so they have to adjust it.
10 hours ago, gotasuby said:
Finally fitted the rest of the Whiteline gear and gave it a wheel alignment. Looks like we all doing alignments at the moment haha
What alignment do you run on gravel? Or is that a secret :ph34r:
2 minutes ago, gotasuby said:
No secret wheel alignment
Front Camber 1.5-1.75
Rear camber 1-1.25
Rear toe out 1-2mm
Front toe out 2mm
Range is depending on conditions and speed of rally.
Was doing road car though
Curious, what are your caster settings?
2 minutes ago, GC8E2DD said:
Usually you would have more camber in the front than the rear on a WRX. Do you have aftermarket camber bolts in the rear and stock fronts?
That's entirely dependent on the setup you've gone for.
I'd be trying to do something Similar with my RA with about -1.5 degrees in the rear, about -1 degree in the front, but with a hell of a lot more caster to induce more 'progressive' camber.
