glion
glion's Achievements
  1. looks like these are low clearance, 6mm. Expensive here in NZ at ~$280 for something I might never use. Looks like i'll use YouShop and get them from Amazon ~$160
  2. I need them for going up ski field roads, so gravel use is must. I'll hunt out the manual and see if I can post the page up.
  3. Is anyone out there running snow Chains on a 2007+ Sti with the Factory 245/40/118 wheels? I've been told the manual forbids the use of chains (can't confirm as Japanese) and that their is not enough clearance between the wheel and suspension anyway. Getting some for the wheel size is easy, its whether or not there is clearance to use them safely.... Then their is the potential if I can get them to fit.... will they scratch the wheels....
  4. I totally understand if you blip or rev the engine enough to cover the gap between the gears the motion of the car will be smooth. I'm only talking whether or not bliping the throttle will make the gear shift movement smoother.... all completed while the clutch is pressed.
  5. How is this possible though.... the entire shift is completed with the clutch in, how can the blip be transferred to the gearbox?
  6. I was talking to my friend the other day, he was saying that on downshifts he blips the throttle to make the shift smoother. I'm trying to make sense of the mechanics of this... If we take the situation where the downshift skips a few gears to make the situation more extreme. Lets say I'm going along in 4th and change down to 1st. My friend seems to think that without bliping the throttle, either the gear will grind, it wont go in, or it will be difficult to get in. Is this true will bliping the throttle make the change smoother? It my under standing of gearboxes that once the clutch is pressed, bliping the throttle will have zero affect on the grearbox, the connect is just not their. Double clutching (hes not double clutching on the downshift) I can see would help. Put clutch, put in neutral, release clutch, rev engine to spin up the clutch, clutch in, change to first. This will help match the speeds of the input and output shafts making the change smooth. I may not have explained this very well.... in one line.... Will bliping the throttle on a downshift help with the change?
  7. I think that reason I can afford the 2010 Sti is that I don't waste the money I have
  8. i just stubbed across this blog post.... of someone in NZ, maybe a member. http://sergei.nz/grb-sti-tgv-deletion/ Sounds like that might be what i'm experiencing.
  9. Yes, if i let it warm up then there is no issue. Is this a standard Subaru issue? Its subtle and its not really a big issue, its just that it could be better. If it was something like bad plugs, or easy to fix then i'm keen to fix it. If the RPM is kept high over 2500/3000 then it doesn't really show.
  10. Who has a good Tyre recommendation or alternatively a Tyre to avoid? I'll soon be in the market for a new set of tires I'd like to spend from $200 - $300 per Tyre. Looking for the best Price vs Performance vs Wear compromise. I was in at the Subaru dealership the other day and they had some very cheap prices listed on the wall. I asked about the brand, he said although it was something i'd never heard of before. He went on to say that their are only 3 Tyre manufactures in Asia, hence they come out of the same factory so their as good as a branded Tyre. I doubt this to be true, although if someone know of re-branded tires at a discount, it would be good to know. Vehicle: 2010 Impreza Sti Tyre size: 245/40R18
  11. When the car is cold the power delivery doesn't seem to be very smooth. It only takes about 30 seconds and then it back to normal. This only happens in the morning as the car has been sitting overnight. If I go to the shops for an hour I think the engine must retain a little heat and it runs fine. Its like the power comes and goes a bit, could be described as a surge in power then its back. What would a likely cause of this be? Hasn't been serviced in ~17,000Km I've changed the engine and box oil though. 2011 JDM 2.0L Turbo Sti.
  12. Its a bit hard to see under the car, when i can only just fit under. I assume this is an alignment hole/pin and not a missing/snapped bolt? Tube is filling the box with oil.
  13. I'm not sure, its my understanding the Gearbox needs a oil without a friction multiplier, yet the rear diff needs the friction multiplier. I've looked it up and all in know is the rear has a Torsen LSD. Can't find out what the front one combined with the gearbox is. What oil can you supply?
  • Who's Online   0 Members, 0 Anonymous, 108 Guests (See full list)
