So still head scratching. I have been through everything I can think of,
latest work done,
- replaced all intercooler pipes with new silicone (in case boost leaks) the old ones were a bit ratty.
- deleted the flexi on the mid pipe on the exhaust manifold (as there was still a small exhaust leak)
- cable tied all connections relating to boost solinoid / MAP sensor.
- rechecked manifold with compressed air
To add to this I took it in crowe sport in chch on friday to have it dealt to as I’m running out of time until it becomes my daily and they couldn’t solve it either. Nothing worse than spending good money on shop time and not be much further ahead, to their credit they gave it a good once over.
So how it runs now, so no problem spooling up to 0.5 - 0.6 BAR if you load it up in second into third it will spool up to about 0.8 BAR but then be accompanyed to a loud hissing in engine bay. I have triple checked all vac lines and connections with compressor and added clamps everywhere.
The hissing of boost makes me think what ever that it is related to, if not the main cause of my issue.
I have not yet use a different AFM yet to rule out that side but need to chase down this hissing hose first to fully rule that out.
I have read on some other forums things like knock sensor / AFM having symptoms like mine but that does not explain hissy boost problem.
basically near the end of time/money/patience with the wagon. Not sure what else to do, can’t afford to have a shop do much more trouble shooting on their end.
