Hi guys.
So i have a 1999 legacy GTB, it has the following mods, V7 sti block, J.E. pistons, con-rods and bearings, v7 sti crankshaft. spilt fuel rails, v8 highflow oil pump. v7 sti turbo. custom aftermarket modified downpipe and 3inch straight through exhaust system.
BUT i am running the stock heads so obviously the stock legacy ECU as well so needs a tune badly.
called up many dyno tune shops all across auckland, no one will touch it unless i buy a g4 link ecu. found one on trademe but i've been told to find out if it will fit my car, this g4 link description is said to fit a V6/V5 WRX or STI and Facelift Forrester. Any thing with a facelift dash and the coil pack for the engine on the LH side.
I have been told that my GTB and the v5/v6 ecu is the same, is this true? If it is this g4 technically should fit correct? What are your thoughts??
heres the link to the ECU: http://www.trademe.co.nz/Browse/Listing.aspx?id=482849507
Cheers guys!
