Matthat
Matthat's Achievements
  1. I have a straight pipe from my cat back, very loud, good rumble on it. I talked to mag and turbo and yes they said the same thing about the suspension. I was wondering if it's possible to bolt on wrx suspension and do it that way.
  2. Hey I want to lower my SH forester what is the easiest way to do this? Also what is the best turbo back exhaust to get installed? I currently have a catback exhaust installed that has a straight pipe, wondering if a turboback will be as loud and hopefully give the car more power. Thanks in advance
  3. Hey I want to lower my SH forester what is the easiest way to do this? Also what is the best turbo back exhaust to get installed? I currently have a catback exhaust installed that has a straight pipe, wondering if a turboback will be as loud and hopefully give the car more power. Thanks in advance
  4. I'll try and record the sound.
  5. It's definitely a noise that has started to happen. Never used to be there
  6. Could it be the turbo? There is no loss of power. It doesn't happen the whole time I'm acceralating. Otherwise it sounds like a sucking sound.
  7. Hey when I accerlate I can hear a whooshing sound only while I accelerate, have had the car checked and it's not the intake, turbo or the vaccum lines. Of course the car didn't make the noise when the mechanic was looking at it. Could it be an exhaust leak? If so where could it possibly be coming from and is it easy to fix? It is on the driver's side of the car, it's a 2010 forester xt, it's the 205, it's standard 2.0L turbo.
  8. The hose? Or just the whole unit? Should upgrade, do I need a tune for a pod filter? Or cold air intake?
  9. Hi, just noticed my forester makes a whooshing sound when I accelerate, it's not always there only under acceleration, it's not the turbo as car still has boost and can hear my bov, just want to know your thoughts. Cheers
  10. There's obviously the low and high mark. Would be a 20mm over the high mark
  11. When the engine is warm, its way over the high level.
  12. Now im not sure if it is the rocker cover gaskets as they both seem fine, I got the car a service about 7 weeks ago, the retards have overfilled the engine with oil by quite alot, the leak is on the driver's side as the oil is dripping off the oil pan and the cross member, any suggestions as to what it could be and how to sort?
  13. I'm pretty sure it's the passengers side with the battery.
  14. No i haven't brought the gaskets yet, I was going to go repco
  15. Do I have to remove much out of the engine to get to the rocker cover gaskets?
