Dubby458
    Never
Dubby458's Achievements
  1. Hi guys i am replacing my front door speakers with kicker 6.5s and i have found they dont fit in the factory bracket or if you remove the bracket they fit perfectly but they hit the power windows instead. What are my options? Cheers
  2. Dubby458
    alternator
    would a ej20g alternator fit a lj20 suzuki motor?? I know a random question but i am selling my alternator and a guy wants to know if it can fit his suzuki?? Cheers
  3. my flywheel off my ej20g has surface cracks!!! can it be resurfaced?? or is it a crook unit Cheers
  4. will a alternator off a ej20g 1996 wrx hatchaback fit a 1999 legacy rs??? cheers
  5. how much are closed decks worth by themself?? cheers
  6. all cars increase in revs when clutch in compressor kicks in, its putting more load on the engine, thats why a/c takes up more fuel cause ur reving higher,
  7. i wasnt meaning to test quantity of refridgerant by seeing if revs increase, i meant to check if the a/c system is functioning at all if compressor is operating. And yes you are correct about sight glass.
  8. ok first all of does the engine increase revs when you press the a/c button??? or if u have it running with a/c on and fans blowing you should see the compressor pulley spinning, if not the clutch isnt engaging and ur air con system is not working either a fuse, compressor not plugged in, or a crook compressor, if it is spinning and picking up revs when on, ur a/c system is working but you will need a regass, which just invloves evacuating the system and recharging to the required quantity. and just a caution if compressor is not operating, its possilbe its fucked it self and put metal shaving through out your whole a/c system so it will all have to be removed and flushed with white spirits, and replace tx valve ect, so dont chuck on a new compressor if the old one doesnt go, cause the shavings will only fuck the new one. cheers
  9. this vin number is off a sti off trademe. Is there anyway to check its a geniune sti??? no is: 7A8GF090704034529 cheers
  10. if so i would just check fuses, and most likely the central locking control unit could be faulty, or just maybe you have crook door motors but i doubt they would all go but it is possible
  11. so using the key in the door it just locks the driver door???
  12. haha thanks, like i really just want to buy a wrx in blue, but painting is a nightmare and very expensive so maybe it is easier to turbo it since i have a wrecked car
  13. btw this is my hx.....
  14. dont worry found it
