lerroy
    Wanaka
lerroy's Achievements
  1. Heading back to Oz for work and will be away a year. Car won't be driven will just be parked in a car port. Anyone recommend a good all weather car cover for a wagon? Any advice for long term storage? Should I unplug battery? Anything else? Thanks
  2. Hey Thanks for the advice I wasnt as bad as deep scratches, I got the Autosol and it worked wonders, although With HID's the fade comes back every few months needs another go with the Autosol.
  3. Pretty sure the parkers on JDM facelift are T20 4 wire. the number plate is T10 not sure interior
  4. Hi all So I had a radiator leak coolant through engine bay all fixed but the under hood insulation material is soaked in it and gets smelly under heat. It\'s also looking pretty ratty. Is it purely a sound thing? Is there any 3rd party alternatives? Or should I just find a scrap yard? Or just remove?
  5. Ok Got car back from repair. Couldn\'t find the yellow and brown wire near the gear stick. I did however find a matching color wire at the drivers kick panel in the wiring loom heading to the back. Used a vampire clip to connect head unit wire and it works great reverse now initiates the rear camera Thanks for all the help Guys.
  6. hahah so true Might have to hold off on the camera install, top tank on radiator just cracked awesome...
  7. Happy to do the wiring from diagrams do you have any I can use ?. (edit i just googled found heaps I have run a RCA cable to the back door through grommet to the camera and tapped into the reverse lights to power the camera on. Would rather not pull panels off again to run a wire back from reverse lights. Ill try and locate this wire around the gear stick the colors give me a good idea now, there was quite a few coming off it for the sport shift. Didnt realise it would be so hard to find as its in the Pioneer install manual "just tap into wire" make it sound easy ahah.
  8. Awesome that sounds like an easier plan
  9. Hey guys I\'m installing a Pioneer head unit with touch screen all installed great just want to wire the reverse sensor so it automatically switches when im in reverse Anyone know what wire I tap into to tell my head unit that I\'m in reverse? I have a legacy bh tip-tronic auto
  10. No this was all for looks. But I made a point to mention that it\'s a snow car to let people know what I use it for, so if these mods effected that purpose negatively I wouldn\'t bother.
  11. So 8mm and 10mm almost three turns, 5mm should be at least 3 then?
  12. Ok thanks for the input 3 twists that\'s plenty haha I might jack the car up, put some temp washers behind see what 5mm and 15mm looks like and work out if its worth it.
  13. hmmm...legal could be an issue. Maybe i wont bother going down this route, thougt it was just a bolt on affair
  14. Great yeah definitely want to do it sensible, with no guard rub The 5mm spacers I see on trade me seems like they are just a washer style, anything over 5mm though has additional bolts etc.. something like this - trade me spacers
  15. Hey all So I have a 2003 E-tune BH, its currently stock height but on WRX 17" wheels powdercoated. I want to give it a more aggressive stance, but its also a snow car (in season) that I want to be able to take up the mountain no issues. So have been looking at options of hub-centric wheel spacers what are everyone\'s thoughts on these ? I dont want to go crazy 5/10/15mm ? I will eventually lower it as well, although not slammed maybe just enough to look good but still not have to worry about holes. here is the car as it stands
  • Who's Online   0 Members, 0 Anonymous, 70 Guests (See full list)
