Needs to be done correctly to get best results. Had my GTO for 7yrs no rusting or flaking. The blue did dull off a bit but still looked good.
from the VHT website:
Curing FlameProof™
VHT FlameProof™ Coating only attains its unique properties after correct curing (refer to instructions on the can).
On the Vehicle
Paint must be completely dry before curing
Run at idle for 10 minutes
Cool for 20 minutes
Run at idle for 20 minutes
Cool for 20 minutes
Run under normal operating conditions for 30 minutes
Off the Vehicle
Heat to 250°F (121°C) for 30 minutes
Cool for 30 minutes
Heat to 400°F (204°C) for 30 minutes
Cool for 30 minutes
Heat to 650°F (343°C ) for 30 minutes
Caution: Do not exceed the temperature of the least heat tolerant component or the base metal
Coating System
VHT provides a multi-high performance coating system for the ultimate in protection and quality. The system includes surface preparation, primer, paint and clear coat.
Prep SP445 Prep Spray
Prime SP118 FlameProof™ Primer
Coat SPXXX FlameProof™ Color
Finish SP115 FlameProof™ Clear
