nizmo
    pahiatua
nizmo's Achievements
  1. Turbo timer? Is it built in to the alarm?
  2. Update. Engine was pulled and heads stripped off. Both head gaskets were gone. Machined the heads and the block. Apparently boost pressure was making its way through the head gasket in to cooling system but the radiator pressure was not enough to get in the the cylinders. Caught it in time.
  3. thanks. new radiator so not blocked. new rad cap. std pressure one. top and bottom hoses just as hot as one another. its leaking all around the seal of the cap. and the fans are kicking in. i contacted the seller who had no hesitation in paying fot the repair. he will pay parts and machining and ill do the labour. i am a mechanic and im sure it is head gasket but just wanted to ask here first. next question. where to get cheap arp head studs and what head gasket to use???
  4. Hi. I searched this but could not find anything. Sorry if it already exists. I brought a v7 wrx on the weekend. It has had a full alloy radiator installed recently. I test drove it and checked it over and it all seemed fine. I drove it home 5 hr trip. Coolant temp fine all the way down. Checked the coolant level following day and was down a bit. Went for a short trip today and noticed the top hose was very hard and coolant was leaking from around the cap. I replaced the cap with a new one and this is still leaking. The top hose is rock hard. Does this seem to be a head gasket issue?
  5. ok found this hope it relates to something, so subaru uses nissan diffs?? i guess go http://forums.hybridz.org/index.php/topic/50499-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount-faq/ so really i guess i answered my own question,
  6. hey how do i tell what rear diff i have, i have herd of r160 and r180, whats better? and how do i tell what i have
  7. i dont know why i bother with this site there are some knobs on here, i want info not stupid comments, thanks to every one who has helped,
  8. yeh been searching, im a mechanic so can build it myself just thought someone on here might know some tricks, all so as comment above saying "buy a nissan" if i wanted a nissan i would, but why have something that 90% of drifters have, not that i want to drift my suby,
  9. hey just quick question, whats the best way to go about building a strong engine, i have a 99 wrx, i dont want to run big power just reliable and no knocking noises, im looking in to a rwd converstion and want something to handle the rev's, whats a good option,
  10. ok so i pull gear box arart and remove front crown wheel, then i weld spider gears in the centre diff whitch is in the back part of the gear box??
  11. so just to get this straight, if i pull my gear box apart and remove the front crown wheel is that all i need to do to make it rwd or do i still weld something???
  12. hi, sweet all this info is great and easyer than searchin, now anyone in the palmerston north arear down to wellington know how to make this converstion, ??? i want to leave complete front axles in if possible, some help to do it would be good,
  13. i have a spare box thats the only reason, and i just want to skid it round a bit,
  14. thanks i have had a read up, any one have some images orf what needs doing,? im a mechanic but have never done it before, but want to keep front axles in for wof's
  15. hey i have searched and not really found any thing, i just have a some quick questions, 1, is it easy to make a gear box rwd, (i have a spare) 2, will it last?? 3, can i leave my front axles in? thats bout it, all the help i can get would me awsome,
  • Who's Online   0 Members, 0 Anonymous, 138 Guests (See full list)
