It started doing this before the rebuild (Thats why i decided to rebuild it). It was a intermittent problem at first. I've had it on the computer at work (Wadsco Motor World) & found no problems what so ever. I had the shortblock assembled at a shop & the heads checked over at the same place. Did the rest myself. I also wired the wastgate shut with no change.( would just hit boostcut & then do the same thing again.)
At the time of the rebuild I replaced all the gaskets & seals, checked the boost lines etc.
The exhaust is 3inch from the turbo back with a siamese pipe for the wastegate. Doesn't seem to be blocked.
If I pressurize the inlet manifold on the car i get air coming back out the idle control valve but thats at 110psi.
Will try a few things & see how it goes. Any more ideas throw them at me! Getting beat by my mates s14 turbo at the drags was shameful!!
