Hi everyone just thought id post some pics of my tt leg build.
About 2 weeks ago i had a sustained high boost / high revs moment (momentsssssss...) on my week old tt wagon.
Thought it sounded like a loose side skirt or something untill I gave the throttle a blip and AH the all too famillar sound of slap happy bearing!
limped it home minimum revs but maximum noise!
Rope towed it down the rd about a km or so ( cheers Ropata ) to my mates house with a lovely 2 post hoist ( cheers the Daneish!) and whipped the gearbox off then constucted my engine removal pallet racking special ( pics when my digi cam decides to behave) and flicked out the motor.
not too bad considerig it was its first removal 2 exhaust bolts met the cut off disc but everything was pretty good.
After constructing gudgeon removal tool version 4.0 ( allen key welded to a long bolt with big washer on the end and a sledge hammer head for slide hammery action) I discovered that #3 big end had mashed itself onto the crank.
Mains didnt look too bad but the other 3 big ends were toasted.
After a degreseing that would make oil barrons lick thier lips (12 cans of degreaser! cheers $2 supacheap!) I took the pistons, rods, crank and pully , and the 2 halves of the block to West Auckland engine reconditioners .
I found them very friedly with A1 service so far I can reccomend them 100%.
Eric reckoned it was prudent to deck the block as the open deck block can get a bit twisty.
They mesured the bore to piston clearance and said that was fine but one of the rods was too toasted to be machined.
So I found 4 sti rods on trademe for $30! already hot tanked and in good nick so they went down yesterday and im eagerly awaiting the progress!
Reco heads on trademe are lookin good and im gagging to get it in there and then start with the single turbo conversion!
Hey any advice on head gasket sorces? good prices? ive got new cam seals and ive seen a oring kit with other gaskets http://www.trademe.co.nz/Browse/Listing.aspx?id=334320806
what about rocker cover gaskets?
Il post more pics when i get my digi cam sorted and let ya know how its going at the machine shop.
Cheers
