Hey guys,
Firstly, thanks for all your help in the past. Real interesting reading in the forum. I've tried searching for my ticking problems but not come across my exact problem so...
I've recently swapped the engine in my 250T. With the new engine there's a tick which seems to be every two revolutions. It's more noticeable at low revs (possibly just 'cos it gets drowned out at higher revs) . It appears to calm down once it's warmed up. I've disconnected my spark plug leads on each cylinder in sequence and didn't notice any difference in the tick, though it was hard to tell. It's only heard when the engine is under load; accelerating or in gear with the break on.
I've used a stethoscope and it sounds loudest on cylinder 2, you can't really hear it on cylinder 1 & 3. It appears _clearer_ on the actual cylinder wall, not on the head. It can be heard listening on the bell housing, but not quite as loud.
My guess is something valve related. Although during the engine swap I was super brutal with the torque converter and may have damaged it.
If it is valve related what should I do next? Can I do much with the engine in situ? Is it worth trying MBL8?
