have you touched the loom yet or is it still standard?
if its standard and a 7c ecu can you sent me a few pics of the ecu and loom , so i can re pin mine back to standard?
a mate told me it would be easy and he did it but the car dosent start . and he didnt label the cables haha
no1 anywhere has a color code diagram
bugger pity u don't still have the car, i need a pic of computer and loom to fix mine.
i have the same computer in my gt also .
i dont think its anything special but my car had one of those anniversary badges on it
hey guys Ive got a 1996 legacy gt with a problem.
Ive done a single turbo conversion and the only thing that needed to be done was the ecu
(to get rid of that code 66 that keeps popping its head up ).
so a mate of mine gave it a crack . it was a failure and so i tried to put the standard computer back in and now it wont start . just ticks instead of cranking .
would anyone be able to take a picture of there ecu and loom (on both sides) so i can match the colors back up?
it would be great if anyone can help as i have no car!!
the ecu in my car is a 4 plug with the blue sticker labled 7C ???
hey just go to the local exhaust shop an tell them wat u want thats wat i did an only cost 190 fitted.
dependes weather you want a chrome 1 for the (wank factor) or nt
got the best head gaskets i could find laminated steel or somthing gen subaru japan
just a bitch having to drain the oil again and replace the gaskets lol .
was hoping somone wous say its somwhere else oh well
had heads off yesterday and replaced the head gaskets got everything all back in started fine no leaks . went for a drive down the road and had white smoke burning off the exaust pulled up and theres quite alot of oil leaked out.
i think its the rocker cover because wat the hell else is there to leak around there
any ideas?
i think it may be broken between a water and oil gallerys not sure untill i get the heads off.
id be keen ta know also !
how does your parallel set up go? i was thinking of doing it but went single insted because parts were free.
wat turbos do u run?
doesent overheat it did once but i thought it ws just a airlock.
were do i get this hg ?
wont be taking it to a mechanic there to expencive haha and + i built the engine myself
just was hoping ma new je's and rings werent munted but i did a compession test and one cylinder was off a bit .
bit it was only out by 3%
97% sure its ma problem but thought id ask ya guys opinio
bubbles in top tank .
two weeks later oily water
should i be 100%
also another question can the broken hg cause a slight mist out the pcv system?
my engine is same ecept for a 3 inch exaust and pistons and no frountmount .
i shall keep it safe around 12 for the mean time .
4* 575cc injestors
sti matching fuel rail
sti fuel regulator
sti ra spec c fuel pump
does anyone think this is a deal i should go for when its only $450
just thought it may have lead to the turbo busting because when i removed the vf8 there was a decient sized crack in the wastegate haha it was wasting the whole time i had it on there . i thought i could hv either been that or the fact there shit an i had it on full boost so it prob just gave up lol.
also just asumed you should have the water hooked up as how can it hurt ?
oh also zarnah do you have forgies ? wats your setup and how much boost do you think can be run safely without doing damage or having to replace ecu?
i blew my vf8 up a couple of weeks ago i think it was because the water couldnt be returned (overheated)
anyway how glad was i that it broke . i have a tdo5h now in my 96 gt legacy wag . wat a difference !! its great i recomend everone with a legacy to do it.
only problem is that the water feed and water return are a different size to the smaller versions of turbos used on the legacys.
lucky for me tho i went to the local subaru workshop got the right bolts for free and only had to spend 2 bucks on some copper washers .
drilled out the doughnut thingys to fit and away i went .
great responce tho!! just need a computer now
this way is alot better than wat i did lol i had alot of swareing going on . wish i new ya could do it this way.
when ya put new gudgens in tho put them in the freezer for a day .
makes it alot eaiser to get in!
