These are the ones I got, seemed to do the trick and they also come in blue if you are that way inclined. Looking at the ones you put up and these, seem to be the same just different sizing, pricing and colour haha.
http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-522703259.htm - 90 degree bend @ 1.75"
http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-523621557.htm - 45 degree bend @ 1.75"
Both require a wee-bit of cutting to the right size in order to fit, but they worked fine on my car.
If I was going to do this again, I would try and find a pipe that had 1.75" ( internal diameter ) on one end, reducing down to like 1.5" or 1.25", because the outlet from both the turbos is quite a-lot smaller then what connects to the inter-cooler. Don\'t worry if you can\'t, you can still get away with these, it just requires a little bit more tightening to get the silicone to fit on the turbo outlets, or you could get creative and make a spacer, up to you.
**note**
I purchased the particular brand because I couldn\'t find any other traders that advertised the correct size. Looking at the other products on trademe, there are better ones / more proven brands with higher tolerances, so you could try asking those traders if they could supply you with the sizes, but I figured that the little twin turbo turbos weren\'t going to be maxing those tolerances anytime soon, so I am happy with the ones I have, lol. If the other traders could supply you with the correct sizes, it might be like a $30-$40 difference, but it is completely up to you which brand you go with.
