Twin Turbo Issues - Need Help
Bazza-NZ
Hey All
Got a BD5 for cheap Auto transmission twin turbo with a driver door that had been hit, spent a few hours fixing [15.5] it up and making it run and just need to sort out the last of them. Firstly it came smoking (at lest 10 packs a day) blue, white, and what other colours etc. Fix this all up and now doesn't smoke
Replaced the primary turbo as this was seized so replaced that and reset the ecu etc... Car currently doesn't have any CEL codes, it flashes advising no errors present HOWEVER:
1. On boost it surges a little and isn't smooth under load, (assuming it reaching boost) It drives find if you don't use a heavy left foot (but that isn't any fun)
2. On the motorway if i floor it it will build up surging a few times until 5k then all of sudden the RPM will drop to 0 as if it hitting some sort of cut.... (would this be boost cut, map cut ???) Its not a bad cut but the car loses all power at the time
3. Sometimes with tight turning at low speeds it shudders a little bit, other times it doesn't ( maybe needs a transmission flush?)
And no I don't have a boost gauge currently installed to see what is happening, but will try and get one shortly
Any ideas where to start looking and at what? Sorry for the question but this is the first time I've ever worked on a twin, hating it but hey once this is up and running i can start spending on the 90 RS Legacy again ;D
 boostin said:
Try an air flow meter for 1 and 2.
For 3, flush the trans.
True didn't think about the air flow meter....What colour / letter should they be? (i think it has a purple C AFM)
, and planning of doing a flush and filter on the transmission shortly so might just bring that forward a couple of jobs,
Cheers bro
Guest boostin
Don't worry about a filter. They only have a strainer in the pan, and in all the time I've been working for Wingers I've never changed one. There for life according to Subaru. You just make more work for yourself trying to clean the pan and get it to reseal.
Had this in my forester when I got it.
Waste gate was sticky and the car was boost cutting.
You can unbolt the actuator and disconnect it from the wastegate. THen see how free the thing is. Mine was stuck very slightly open and wouldn't open much. Would cause boost creep on the motorway when cruising, causing the speed to fluctuate without the gas pedal being moved. And if I dropped a gear to accelerate it would cut, like the car hitting a wall.
 boostin']
Sweet, always good to know :)
I assumed this was the case as well, so i used my air compressor on the lines and slowly built up pressure to see the end result, all of the actuator worked perfectly fine
I might do your trip and remove them and just check it all out again using the above method
