speed sensor problem
i pulled my partners cluster out of her car (1997 gravel express) the other day to change a couple of bulbs. all went well plugged all the pluge=s back in and put the speedo cable back one screwed everything back together and went for a drive.
About 10 min into the drive cheak engine light comes on so i pulled over and it's spitting out code 33.
The thing thats confusing me is the speedo is still reading right
Any one got any ideas im stumped
If it runs a a cable sppedo then therwill be a small "reed" switch on the back of the odometer
This sends the on/off or I/O signal to the ECU (VSS#2)
If you only changed bulbs the you shouldnt of damaged this, sure you werent clocking the odometer ?
Reasonably common to damage this when odometer is wound !
  • 5 months later...
