Dash indicator lights disappearing...one by one!
matt1710
Hi
I have a 2000 Legacy GT-B E-Tune. Some time ago, I drove a short distance (like 2km) with the handbrake partially on (doh!). About the same time, the red indicator light in the dash that illuminates when the handbrake is on, has not been seen since. A while later, the green indicator light in the dash that illuminates when the headlights are on, started refusing to illuminate - and hasn't been seen since.
Any one have any idea what is behind this and how to fix it?
Any advice much appreciated!
Matt
Have already checked both sets of fuses - maybe I'll have another look though.
As to the 'check bulbs' advice - I assume you mean the bulbs hidden in behind the speeddo/rev counter? If so, how does one get at those?!?! I just replaced the HU and that was a mission, so can't imagine what getting at the bulbs behind the dash is like.
JUst read another thread on a similar topic which suggested that water in the rear brake lights might be playing a role in funny dash light behaviour. I have had serious water in the brake lights issues that I was unable to resolve (despite many attempts!) and finally resorted to drilling 1.5mm holes in the lights - now it's MUCH better. But - could this be causing the dash indicator lights (currently just handbrake on light, and headlights on light) to go??
Electrics in a car are a funny thing. If its common that that issue may happen with water in the lights then it might well be causing it.
I would clean with Kerosene and some warm water and bubbles your drainage channels for your boot. Water shouldnt be getting in to your lights unless theres a blockage somewhere backing it up.
