Rear diff issues- BLE legacy
Unseen1
*sigh*
So apparently my rear diff is making bad noises.
Car is a 3.0r BLE Legacy, 2004, 145kms or so, automatic.
The rear diff pinion seal was replaced last June by Armstrong in Lower Hutt. Oil was obviously a bit low before it got fixed, but it was never noisy at all. A couple of months ago I got a whine, which I thought was a wheel bearing, took it in to get fixed, my friendly local mechanic got under it with a stethoscope and determined that it was rear diff pinion bearing. Oil is full and clean in the rear diff.
Perhaps I\'m cynical, but if this happened often I would be able to find information about it online. It doesn\'t seem common.
Does anyone know about these things? If Armstrong hadn\'t put my pinion seal back in correctly, could it damage the bearing over time? Could wrong oil damage the bearing?
If I need to replace it (grrrr), is there anything I could look at as an upgrade? It would make it easier to spend the money.
Sorry for the lengthy dissertation, thanks for any help!
-Pete
