No compression - Rebuild or Replace?
Flunk
You could still just use the ej20r block with the heads from the ej20h... Will probably need to use the same sized head gaskets from the ej20h as I think the compression ratio is 9:1 and the later model ej20r is 8:1. Someone on here should be able to confirm though.
