Rod and Case bearings EJ207 V7
l2eeFer13
After a bit of help with choosing bearings
Ill be going with ACL but am unsure about the "thrust flange". Their are kits for it to fit middle #3 or end #5. Im presuming its the big bearing that slots in from both sides? So in the pic below it will be the end bearing which i have labeled as #5. Is this correct??
Then theirs the conrod bearings with either 48mm or 52mm sizes. What set will i need? This is just after a quick look on trademe auctions
If anyone needs help with this in the future. This was from ACL directly
"Your engine would be a Phase 2, which are 1999-on. Phase 2 engines normally take the mains sets with #5 thrust as you thought, and have a 52mm journal big end.
So part numbers are 4B8296H and 5M8309H"
