Battery tests fine, no resistance between battery posts when its disconnected from the car
i only get resistance of 15ohms when i disconnect the +ve lead and test between +ve lead (not battery post) and negative lead but yeah i realise thats f***ed haha, thats why as soon as i tested it i was like arrrrrrrr that not good
Yeah i might just order a new alternator to rule it out - heres hoping i can find one haha
Something is f***ed here, if you put a car battery across a 1 ohm load you get a good spark and a lot of heat very quickly. Unless everything involved is rather large.
Suspect something is kooked with your alternator.
