  • Upcoming Events
  • Member Statistics
    8,635
    Total Members
    1,713
    Most Online
    Tyuru
    Newest Member
    Tyuru
  • Who's Online   0 Members, 0 Anonymous, 120 Guests (See full list)
    • I’ll be going, on the Saturday - anyone else heading out? would be cool to see some club subbers there come say hi if you see me 💯
    • I got the dashcam in the GT-B the other day and managed most of the radar detector install too. I need to wrap that up! Last two real things do to are install this Fujitsubo and rear shocks. It is as hot as Hades here these days.    Also signed up for two days on track in October. Planning to take the 2000 GT one day and the 2005 GT the other. The Subaru Stork may also be making another delivery in a week or two...stay tuned.
    • So far, so good. canbus drivers etc all installed ok. Also found that every reboot of pc that programs the microcontroller it resets the memory size and partitions where normally it remembers them. This isn’t a big deal but is annoying. A custom board description file will fix the issue, so have to learn that next. It will help with final version for others to customise and install their own software.   Tomorrow I have to dig out laptop with the canbus software and usb canbus sticks  and setup a testing network again.
    • For the PopeMobile - I threw in the Alpine Headunit from my WRX into it. Definitely a step up from the Fusion.
    • Well wasted most of a day chasing an issue with chips not flashing. Desoldered parts rechecked with multimeter as seemed to be a possible short or something in the design blocking normal boot up.   I ended up tacking some wires directly to another microcontroller in the batch I have and it had same fault. Seems the older chips I got have a higher current draw than my normal programmer supports. Finally dug out an older one and got code to upload ok. re-soldered everything I removed so tomorrow I’ll try the canbus. After that I’ll build up another board and fit it into the case with LEDs and light sensor as a finished unit.   If this works I’ll order the newest 9th revision and also the power/can board for the tiny LCD screen ones.
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
