Westy177
Westy177 last won the day on September 29 2019
Westy177 had the most liked content!
    -98' RS-B Sedan (forged, Single turbo)- Own
    -91' Legacy AWD Brighton- Sold
    -90' Legacy GT Series 1 Turbo -Own
    Cars
    Hamilton
    Auto Glazier Tech
1,433 profile views
Westy177's Achievements
  1. Yes! Cheers for the tag mate
  2. That's reassuring at least. Man v3/4 is a pain haha
  3. Both of you guys have recommended phase 2 injectors to me Ihave phase 1 rails pretty sure they dont fit?
  4. I'll look into those jecs injectors. I hate side feeds because there a pain to fit and I always break them Haha. Um I already have flowed and cleaned by dtech yellows in my car. I've heard mixed stories about stock yellows not really willing to find out if the max out on a vf30 on the dyno. Plus I have these pinks so future proofing.
  5. Hey guys picked up a set of v7 sti pink injectors off a rev d gtb at pick a part the other day as a budget fuel injector upgrade for my RS-B. Since cars a version 3/4 I've heard the manifold on these is unique to the 1/2 5/6. frustrating since all the kits are only for 1/2 and 5/6 or its usdm stuff. I emailed radium engineering about there set but said they will not fit oem injectors, not really interested in going with id1000's since im still on a vf30 nothing special. What have you guys done or even better any links to a fuel rail kit or adapter etc I could run that will work? Any advice or wisdom on the different version and manifolds would be awesome as well. Cheers guys.
  6. Wasn't too sure if this falls under Engine or electrical? Anyway been having a very odd intermittent CEL issue lately, cars a 1998 Gen 2 legacy RSB Single turbo conversion.... note I converted it a long time ago and has been mint so far... Basically driving down the road CEL turns on then it dissapears when i put the car in neutral this is the only way to clear it, I have narrowed the cause down to occasionally when i downshift and rpm falls below 2k and when I accelerate hard out of a turn from lowish rpm. I ran the codes using the black plugs and all I got was 24 so IAC which is very odd as this has been cleaned less than 1000ks ago. Now in the name of rnd I got this cel while going for a spirited drive with my flatmates and noticed I can pull straight through all the way to redline (well 7k dont take it past that ever) and it has no effect on boost etc however between 3-3.5k it has a massive deadspot, last time i got 24 im 100% sure I was in limp mode 4.5k cut etc. Now I could go to subaru when they open and buy a brand new iacv but I'm just not 100% sold on this being the issue, wondering if anyones had similar issues Ive read through other forums with no sort of quantifiable answer. Cheers.
      • 1
      • Like
  7. not 35 not 25 probably not even 20 hahah
  8. Thats appalling!!! I work with panel shops as a auto glazier and the attitude some of them has is disgusting. Get your insurance to kick there arse thats bloody slack.
  9. 4 new tires on the rs and service ?
  10. got this old beast running again!
  11. Finished putting my bf5 manifold back together soldered on new tps and water temp plugs as old ones exploded from being brittle. had the day off so ran around hamilton grabbing all nessasary gaskets and hoses to get this project out the door. also painted the ac bracket and the factory heatshield vht high heat black.
  12. So up until recently my daily driver was a 1991 BF5 legacy brighton, she was a sohc na automatic slow as hell and not the most inspiring drivers car however it was a bloody good car. I made a stupid decision and bought a honda god forbid integra vtec it was full of issues and a bit of a stuff up on my part not a good buy. Shortly after I sold the wagon, from the moment it drove off I regretted the decision, from the point I vowed to own a turbo model off the same car I had before. After whinging on facebook about missing my beloved wagon a friend of mine messaged me about a Series 1 (big plus for me) Gt he had that needed a new home, it was cheap and very tidy drawback being no wof no reg auto and something off with the engine a misfire, lack of power. Unlike the integra this was a car I was determined to have so i got it for a nice deal arrived at my house with a v3 sti gearbox in the boot and all the bits I'd need to manual it. So it was looking to be a manual conversion and diagnose the engine project, I mucked around with changing spark plugs etc as it had 1.1 gap plugs in it haha. The engine was not looking to e running any better I got told its likely a burnt exhaust valve. Immediately I pulled the engine and started the manual conversion. Engine was sent away to be fixed the burnt exhaust valve theory was 100% correct and the only issue the shortblock is perfect even after 207,000ks. V3 wrx heads were fitted as an upgrade over the dated GT HLA heads. While then engine was away I cracked on with the manual bits, cluster swap to manual, auto box removed driveshaft and all related bits. Manual box back in manual gt driveshaft, pedalboxes and clutch cylinders. As it sits manual swap stuff is 90% done and the engine just needs some gaskets and misc replacement parts. Unfortunately I didn't take much photos during this and I also formatted my phone so lost alot of photos. But I do have some for now I will just post photos showcasing the car, I will upload more over the next couple days as I finish it up. The main goal of this project is to build my perfect daily drive a subaru wagon with power but stock reliability while preserving the immaculate factory car that it is. Loud exhaust is a must for me so the factory nana pipe is getting binned but aside from that stocko. been sitting a while but bone stock unmolested engine bay! Gt and the banana RS lurking in the background gt and the flatmates R33 pristine interior Aesthetic shot of the series 1 garnish thats all for now more to come in the coming week.
      • 2
      • Like
  13. my logic, i change mine 500-1000ks but ive only done 2100ks on the engine so ill switch to synthetic next oil change as rings have set.
  14. I run 10w40 penrite mineral 5l on my forged rs, change it every 1000ks lmao because it gets absoutely thrashed the rare occasion it leaves the shed. plus when you drop 10k+ into a car you get paranoid.
  15. I've had a 1kz surf turn his lights off to pass me on the cambridge expressway. im no saint though because then i started playing with him rolling into boost in 5th haha. on the most part my legacy glides miles below the radar police and other modified car owners alike.
  • Who's Online   0 Members, 0 Anonymous, 107 Guests (See full list)
