That was why I said to load the new tune in The rocker cover breather vacuum hose leak you had was of course an issue and diagnosing issues is 90% of my follow up work in majority of cases etc. Other than defining the rest of the software for your ECU but the safety factory compared to the rattley factory tune which was on your car that was pulling 15 degrees out... now it does not pull timing at all(just needs the final .7 degrees added in now IAM can be set)
[quote name='Andy_Mac said:
Just impossible to get hold of. Still need a tweak for my one but haven't heard back from him yet.You have a flex fuel sensor or have to fill completely up each time. Think he was talking about some ecu's actually being able to work out the percentage just from the AFR's or something these days but can't remember if he was talking about subaru's or something else.
You should of had email already No Tactrix means my wife/secretary interprets that as can wait 3 or 4 days. I pumped out 411 emails in the last week
1Mb ECU's have flex fuel available in them no issues. Unsure of your ECU just yet since it needed so much extra for a full definition since the listed definition is wrong etc That said, your injectors would be out of flow
If it is urgent... put STAR in the email address. Usually 24 hrs min turn around
Yeah, looking at options while I am over there. I may be setting up a dealer/tuner in Auckland for them
[quote name='evowrx said:
You can etune these?
Yes, e-tuned a few of them. Tune themselves is pretty solid gains. Typically 180 to 190Kw on 17psi on 98RON, Seen 230Kw with decapped injectors on E85
Other way is to contact me for postal details and you can send an ECU to France yourself and have it posted directly back(less postage etc)
Australian V5 2 Door STI known as ARGO, its a dedicated track car.
Pricing varies depending on the Euro:Dollar but typcially AUS$500 posted on exchange(I have stock, post it to you with a cored deposit, post back stock ECU for full core deposit refund etc) plus price of the custom tune etc if wanted or doing it yourself etc
Heap of extra options available though
http://www.eculabs.com/
Screenshots on the website
As above, I am in Auckland and driving to Wellington then flying to Christchurch for some tuning. Happy to offer some obligation free tuning if anyone is interested I am 99% conficent the DBW and horrid timing maps are the issue you guys are experiencing in the H6 engines.
I am the EcuLabs distributor for Australia, I have stock on exchange all the time. Got V5/V6 STi, WRX, 98~00 B4 Twin Turbo and 98~00 Forester GT in stock
ESL is good value for what it is AND it is easy to use if you have used EcuFlash before
http://forum.liberty.asn.au/viewtopic.php?f=16&t=21900&p=319564&hilit=Tensioner+cam+gear+water+pump#p319564
Tensioner on passenger side head is always worth replacing while water pump is off
ALSO, always ensure oil level NEVER drops below the Low line... otherwise the big end bearings will quickly make an appearance in the sump
Horrendously boost spiking in 2nd graph(maybe factory WGDC values at low rpm) as well, the auto is not liking the power delivery. VF38/VF45 are way off their compressor efficiency at that boost
That auto in the first graph is pulling trans line pressure to protect itself the way that spikes and dips before slowly recovering. Our local AUDM Gen5 usually go from 132Kw to 185Kw with just a tune with the auto holding correctly(decat dump pipe ran a 13.3 1/4mile)
No need to get a Link these days when ESL offers tuning solutions on the stock pre-98 ECU's via daughterboard. Even have dual map options(98 and E85 or a fuel economy low boost tune and an aggressive big boost tune in one tune etc)
