disasembly of aurto gbox.
dubbedup
 CUDDAS said:
some quick pic's, I'm not going to remove the diff as there's nothing wrong with it, & it didn't refresh my memory either, Hey Boostin once the back lash & bearing shells have been removed, i'm sure the inner cv stubs can be removed from the diff, but it been years like 8 or so years ago when i did this last & even then i just pulled stuff apart to see how it worked, any idea's mate :)
Yeah pull the stubs out, then the bearing cups etc out, then the diff should be able to be maneuvered out from there.
The diff casing needs to be separated from the rest of the trans though.
not sure what part that is...but Im also struggling getting the 2 bits out the inside of the other half of the trans.... the main bit wiht all the band inside it and like a long part that goes from start to finish
The thing with 4 bolts holding it in is the diff end of the pinion shaft. It runs right through to the transfer gears at the back of the trans.
Got pics of what you're talking about?
I think the one at the back is a 34 or 35mm socket. I usually just rattle it off.
That whole face that picture is looking at is the oil pump. It has to come off to get to the rest of the innards, and to get it off the pinion nut has to come off the back.
ok so from here i take pinion shaft out, by undoing nut and removing it (i have already undone the 4 bolts) then i have access to otehr shaft, i have undone teh allenkey end, is there a knack or will it be obvious when i get the pinion shaft out?
CLICK!!!
i have tried to remove the face but couldn't get it to come off but once i remove it it will fall to bits basically?
Yeah, you just gotta get that nut undone and then smack the end of the shaft where the nut was with a soft hammer, or a hard hammer with a bit of wood against the shaft.
Once you crack that nut off it will be pretty easy.
If you put those 4 bolts back in the pinion bearing flange, when you whack the end of the pinion it will pull the whole oil pump assembly off the trans case.
Did you get the diff out in the end?
ok so im looking at this and i cant see a way of getting the axles out, other than undoing the 12 or so bolts holding the diff together.
there appears to be a key way to lock it up but cant see anyway of undoing it..
pic of keyway bit.
DSCF6622.jpg?t=1271757989
bigger shot, bearing off.
DSCF6621.jpg?t=1271758033
Stick a phillips screwdriver through the hole in the stub, then chuck a lever or 2 under it and flick it out. You don't need to undo the 12 crownwheel bolts.
