What Grease to Use?
What grease to use?
I'm looking to re-grease some shock have before i put them in just to ensure i can keep then in the best possible condition. I have a set of V7 / V8 STI shocks so looking to keep them well greased to stop knocking etc..
I've used the search function but the results i got where someone useless and still a little confused about what to use, as
What grease do i want to use for this process , Name / band etc would be good if you could
Thanks
Will do a write up on it once completed the re-greasing process
No, that's too thick and sticky. Go to Repco and buy a tub of Valvoline wheel bearing grease. It matches what you need.
