sti upgrades
have got a sf5 fory that ive had since dec last year and after using it as a daily driver for a while i want to upgrade suspension, intercooler, seats etc for sti bits. i understand that gc8 sti pink struts fit in once u change the rear hats but do u need to do anything else besides the obvious wheel alignment? are standard wrx sti springs enough to drop the fory to a reasonable height or would i still need lowered springs? i dont want to put them in to find my alignment is too far out to drive to get alignment done and need to get something else to make it drivable. basicly i want specific chassis codes for bits that will fit such as what front and rear swaybars will fit straight in without modification, what front and rear strutbraces will go straight on, tmi etc... i figure with all the mods done to everybody elses rides already that u guys have the experience us newbies are after to make modifying our forys easier. anyways any help would b greatly apreciated.
Hey mate, GC8 stuff does indeed need its rear hats swapped over, go one better and fit GDB ones ;) other than that all you'll need to go is that mentioned wheel alignment (putting standard wrx/sti struts in will lower your car about the same as a set of low/super low springs would). Would also change the rear sway bar for an STI one also. Apparently the front is already 20mm but your rear would only be 10mm so this alone will make your foz hit those corners with alot less difficulty. Ive fitted a GC8 (version 4 or 5) rear sway bar and the difference is amazing!
hope this helps
v7 intercooler fits if you don't have a IAC valve in the road coming off the rear of the intake manifold.
as matt said, v7 struts bolt straight up and lower decently
front bar on foz is 20mm standard 14mm rear standard, v6 bar fits with no mods
front strut bars off gc8 wrxs fit with standard intercooler, if you have larger TMIC you will have to custom make a front bar as i have had to do.
rear bar needs to be forrester one or maybe v7 wrx as gc8 will have incorrect bolt pattern, i ended up with a forrester specific one
try looking on ozfoz.com for more info, all those guys are pretty onto it from what i've found.
Craig can we get a pic of your engine bay as it stands today? Just to give us a better idea on V7 mods etc.
And sorry can you explain the IAC valve for me and exactly where it is seeing your old thread died with the old forums?
 nt_a_foz said:
Hey mate.
Do you want some sti injectors, afm and ecu.
Good upgrade for foresters.
Got some for sale.
Brad
God I love this site lol :D
Will grab this type of set up one day.... love how a lot of the things I've been looking for (a while) pop up here on what looks like a regular basis.
Rock on.
