dccd centre diffs and front diffs
I know this is a pretty out there question and i'm sure its not practicle but thought i'd ask anyway....
Is there anyway to use a dccd centre diff as a front diff?
The reason i ask is that i'm using a locked centre diff subaru gearbox as a transaxle in a mid mounted engine racecar. Its running really wide slicks so needs way more lock-up in the front diff than a standard lsd front diff has.
Would be unreal to have the versitility of a dccd front diff!
Anyone else using a subaru box as a transaxle?
use a plated diff, they arnt cheap but then it will handle the curry your goin to give it.
edit ^^ beaten to it. kaaz make good diffs too.
