Couple of boost/vacuum question - GTB BH5 Rev D
Remembering mine is tiptronic (i like it so shhh ;D) i'm now boosting 14psi on Primary, dips to about 8psi in the change over and back up again to 14psi on secondary till 6200rpm and then tapers off to 10psi... spoke to the guys at Strong for Subaru too who reckong thats about perfect... happy now...
I think one of my vacuum pipes was cracked - hard to tell coz it snapped when i removed it, but with the replacement she's going hard again... 8)
 pharnos said:
will try some 3rd gear runs (40kph up) and some 5th gear runs (80kph up) and post up the data logs
mind the above logs were not launching the car from standstill, they were squeezing through light accel in 1st
but yeah, interesting that the primary only shows 10psi ... maybe cos in 1st?
Yeah try a higher gear on the primary, you should see about 1 bar, i still make 1 bar in 1st but only if you load it from down low
