HTF?? Files....
So recently rebuilt the donk in my wagon, havent run it for about 6-7 weeks (previously running fine just adding more shiney parts :P), fire him up and I have no boost..... rude.... have a look at the trouble code my ECU is spittin out and its "Boost Control Soliniod" so I go through the appropriate steps in cleaning it...fail, run test with the green connectors connected....seems fine?, use a known good one from another car...fail didnt change a thing... :'(
So I thought thismorning id have a look at the intake/turbo and upon removal of my pre-turbo intake a tiny little 8mm nut comes tumbiling out........"insert cry here"
I know exactaly what it is, the nut from the intake impeller of my turbo... upon futher inspection there is damage to the housing, spool, and the bearings are shot....HTF??
Was fine one day then doesnt get driven for a while then the turbo just decintergrates? ???
Ohwell good excuse for a new bigger one eh?
The nut usually only comes off when the compressor jams and the turbine keeps spinning. Maybe a lack of oil to the turbo?
yea when I had the compresor off it seemed oddly empityish, as in not much oil came out.
I suspected asmuch and there is a Grrisholm style investigation going on.... lmao
