Random ECU help
jazza
Kia ora guys, have finally got a WOF on my 89 rs legacy so time to drive it and have a tutu. The previous owner said the engine is a GTB block and WRX heads...unsure version/year. Anyway the engine is standard running a td04. When i got the car it had a "modcontrol" chipped 91 RS ecu but came with a '89 RS ecu also. car was hesitating from 2000rpm-4000rpm then went mean there after, first thing was to put the standard '89 ecu in and goes better but a litlle bit of hesitation. Anyway ive been looking under the dash and have found this box thing tied to the steering column(see pics) and am wondering if it is standard? Also would an old RS legacy work fine with the gtb/wrx engine hybrid. cheers, Jarrod.
45094_1597825548488_1321488818_31651094_
the ecu that is '91RS
45094_1597825588489_1321488818_31651095_
looking under the dash, the box is the black and grey thing with the cable tie..its tied to the steering shaft
45094_1597825628490_1321488818_31651096_
