Not subaru, but removing nissan RB oil pump
forcefed
You should be able to, there's 4 x bolts holding sump to the oil pump and 8 x bolts holidng the pump to the block, remove everything off the front and you should be good to go (been awhile since I worked on a RB).
Here's a photo of a RB pump to give you an idea:
